shift changer
Old Mar 10, 2010 | 10:15 PM
s4yama's Avatar
Default shift changer
Has anyone used the upgraded shift changer that speed factory offers. I am having trans issues and was wondering if the upgrade would be a good place to start. Thanks
Old Mar 10, 2010 | 10:22 PM
cibao2ner's Avatar
Default Re: shift changer
what issues are u having?
Old Mar 10, 2010 | 10:25 PM
InDub's Avatar
Im running it as well as about 5 other cars in my shop.
Its a very nice piece and holding up perfect so far
Old Mar 10, 2010 | 11:14 PM
s4yama's Avatar
I can't speed shift into third and fourth, i have to baby it into those gears and thats really killing by e.t.
Old Mar 11, 2010 | 07:24 AM
locash's Avatar
I use the SpeedFactory part and it is well made.. You may want to make sure your transmission doesnt have any other issues as well..
Old Mar 11, 2010 | 08:36 AM
Full-Race Henry's Avatar
Im using the SpeedFactory part as well and and it works great.
Old Mar 11, 2010 | 10:28 AM
cibao2ner's Avatar
i had a problem shifting to 3rd..it would lock me out at high rpms..but i changed my bushings and went with solid mounts and never had a problem after that..but the sf shift changer looks like it will help...maybe yours is bent inside..
Old Mar 11, 2010 | 05:17 PM
PaulPero's Avatar
does it grind? are you sure its not a syncro or worn gear?
Old Mar 11, 2010 | 09:19 PM
s4yama's Avatar
I already replaced the third and fourth synchros and also third gear. But I also had a handcuff that used to leave a lot of aluminum shavings in the oil, so i removed it and installed fifth gear. Thanks for all the info looks like I am definetly going to get a speed factory change holder.
trixr
Apr 20, 2008 08:26 PM
sohc prelude
Feb 26, 2006 07:26 PM
bee16a
Jan 10, 2006 01:21 PM
JDM4DRACCORD
May 23, 2005 09:03 AM
Juantay19
Apr 2, 2002 10:43 AM
