Please help with Auto to manual motor wont start
Old 09-20-2009, 11:36 AM
N3DRO's Avatar
Default Please help with Auto to manual motor wont start
Ok, I have a Canadian 93 hatchback dx which was automatic with a stock d15b7. I swapped that engine out for a 95 ls obd1. everything is installed already ( clutch pedal with clutch master cylinder and new clutch line, shift linkage, shifter and welded metal to seal the holes correctly,auto to manual tranny mount). engine is in. when I turn the key the dash turns on with no problem just like before but when I hit it to crank up, all it does is a click on the fuse box. My friend old me it might be a ground missing but i replaced all with new ones last night and still same thing.
1. I switched all grounds with new ones ( tranny, valve cover, battery).
2 the ls obd1 engine harness has a map sensor plug and also the cars harness has that plug too. I have tried with both and still same issue.
3. I'm not sure if there's anything to be done to the plugs that go connected to the automatic shifter but all I did was tuck them and tape them to the firewall around the heater core.
Any help is defenetly appreciated.
Old 09-20-2009, 11:46 AM
TheCivicMafia's Avatar
Default Re: Please help with Auto to manual motor wont start
Just because dash lights turn on, doesnt mean your battery is charged. Turn your headlight on see if they light up good. and let me know.
If lights work, answer these questions:
Does the starter have power?
Is does your motor turn over if you turn it manually?
Old 09-20-2009, 03:24 PM
taztwnpa's Avatar
I belive you need to jumper the neutal safety swith by the shifter. i think i saw it in a diy.
Old 09-20-2009, 03:46 PM
N3DRO's Avatar
Thanx for the help, I just got back inside from my garage. The car did turn on finally and yeah it was a wiring issue with the automatic shifter plug from the car harness to the automatic shifter. There is I think 2 yellow wires that needs to be connected together and then there a fat cable from the main plug that I did a cut off switch with.
vtecwreck
01-21-2014 09:58 AM
mister_ej2
02-10-2008 06:20 PM
boostedteg4dr
01-18-2008 05:43 PM
danwants2btheman
09-13-2006 12:33 PM
bman511
05-02-2005 04:48 PM
Quick Reply: Please help with Auto to manual motor wont start
