p08 vs p28
Re: p08 vs p28 (mortificationrock)
like said above the p08 uses a one wire. and the p28 uses a 4 wire.
the maps are almost the exact same, even with a 4 wire o2 and running a p08 your not gonna see any power loss or gain.
however, if you use the p08 with your d15b you will get better mpg
what i did was put the p08 base maps on a p30 base. chipped the ecu and used that. worked 100% and ran very good a/f ratio. for stock it was like 12.5 WOT
dblock91
02-03-2005 05:58 PM
hYbRiD EeEkAy
08-16-2003 10:51 PM
