Oil in Spark plugs.
Old 01-25-2011, 06:04 PM
xJohn18's Avatar
Icon6 Oil in Spark plugs.
Hello, I have a problem with my 2000 Honda Civic Si. There is a oil that had leaked into spark plug 3 and 4. 1 and 2 are fine, but 3 and 4 were soaked in oil. I cleaned it as best as I can, changed all spark plugs, and also the wires. The problem is that the car won't turn on now. As I try to turn on the car it sounds like as if wants to turn on, but it just doesn't go. I'm not sure what the problem can be as of right now.
Old 01-25-2011, 06:11 PM
Linked's Avatar
Default Re: Oil in Spark plugs.
make sure the firing order is correct, you may have crossed them over since you did the plugs
Old 01-25-2011, 06:15 PM
xJohn18's Avatar
I'll have to check that tomorrow. Since the car stalled by my friends house and it's over there. That's the only fortunate part about this situation.
Old 01-25-2011, 06:32 PM
Linked's Avatar
since its a distance away, its a good idea to get together a list of things to do in one trip
i'd try checking the firing order
checking for good spark (bright white w/ bluish tint)
and a little side note that burning oil aids in ruining a catalytic converter, and a completely clogged/bad cat will allow no air flow
Old 01-25-2011, 06:39 PM
xJohn18's Avatar
Also, when I removed the new spark plugs from the engine it had oil at the tip. I'm pretty sure this is a bad sign.
Old 01-25-2011, 06:41 PM
Linked's Avatar
you've got a bad valve seal leak in those cylinders im guessing
Old 01-25-2011, 06:47 PM
xJohn18's Avatar
In order to check the catalytic converter all I have to do is just remove my headers?
Old 01-26-2011, 07:30 AM
xJohn18's Avatar
I checked the spark plug wires and they are in the correct order. I tested if there was voltage flowing through the wires and there is no voltage flowing through them. I checked if there was a fuse that was blown, but there is none. I'm guessing it can be relay?
Old 01-26-2011, 07:44 AM
Linked's Avatar
you cant check for voltage at the wires with a multimeter, you'd have to check for spark with a plug or spark tester,
Old 01-26-2011, 08:18 AM
Bligh's Avatar
Check for continutity in the wires.... Sometimes when the wires are removed it's easy top pull the wire away from the connector at the plug end. Also as was mentioned you should check the the oil seals in the valve cover are in good condidtion and not allowing oil to leak and run down the plug. Best of luck with this.
Bligh
Old 01-26-2011, 11:24 AM
xJohn18's Avatar
Thanks for all the help guys. I figured out the problem and it was the ignition coil. I put a new one and it's working like new. Thanks again for all the help.
Old 01-27-2011, 06:03 PM
93HondaDelSolSi's Avatar
when you were talking about oil leaking into the spark plugs were you talking about the spark plug tubes?
oakpwr
04-28-2009 10:47 AM
Midori Green
15
05-25-2007 12:39 PM
LEVEL4
08-31-2006 06:42 AM
tomster
08-29-2006 02:11 PM
sleepy_hatch
04-13-2005 03:24 PM
Quick Reply: Oil in Spark plugs.
