oil leaking from not sure where
Hey guys, for a couple month i realize that from somewhere oil is leaking looks like its from my head gasket but i would doubt it, here are some pics
i wiped it before with a rag and it still comes back
and
and
Re: oil leaking from not sure where (elementb16a)
check the cam cap, plastic cap right behind the VTEC solenoid. Check underneath the distributor for a black streak of gunk from the oil leaking from the distributor O-ring.
It could very well be the headgasket it self, as it is in my car.
Re: (-HONDA-)
Yeah if your not leaking from the cam cap or the distributor o-ring it`s the head gasket. Check your compression and if it`s good then it`s just leaking around the oil gallery seal in that corner. It`s still a leaking headgasket but not as serious.
Cool Cool Island Breezes. BOY-EE
Re: (95ProjectEJ1)
Its your headgasket or your VTEC solenoid. It's common. Your headgasket is leaking externally, so you wont see a pressure drop inside the cylinder. Try sealing up your VTEC solenoid gasket with silicone or getting a new one after that, Just look the other way on this one
Re: (Firstoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firstoost »</TD></TR><TR><TD CLASS="quote">is that a pube on your engine stamp?</TD></TR></TABLE>
Lol must have gotten horny with that B16 lol.
Re: (stdefhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stdefhatch »</TD></TR><TR><TD CLASS="quote">i had the same problem, just not as bad and i changed the dizzy o-ring, cam seal, and the solenoid gaskets and my problem was solved. </TD></TR></TABLE>
