B16a2 w/ LS PR4 pistons, stock ECU, stock map sensor - problems?
Would I run into any problems running this lower compression piston in my engine? I had them in for turbo, but now I'm putting it back to stock. I don't want to spend the extra money to replace the pistons if it will run OK and PASS SMOG with this setup. I don't think the compression change is very much. Not sure if it's enough to make a difference.
Anyone insight is greatly appreciated.
Thanks,
Sean
Thanks,
Sean
Yeah, I'm in no need of power at this moment. I just need it to run and drive around california legally.
Any other insights that might have a for sure answer? I need it to pass smog
Re: (numberone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numberone »</TD></TR><TR><TD CLASS="quote">Your comp will be about 8.5. Pretty low </TD></TR></TABLE>
I know
I know
Re: (highrev1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 »</TD></TR><TR><TD CLASS="quote">chipped ecu, what was your fuel management before when it was turbo</TD></TR></TABLE>
I had an OBD I ecu with hondata - those don't go over too well in California
Re: (Sean @ ESG)
it will fail on smog. the lower compression is not efficient enough to burn off all the fuel in the combustion chamber. you will probably fail on HC
99black_em1
01-19-2013 09:37 AM
_inline4turbo_
04-30-2009 08:06 AM
slimjimming6688
12-15-2008 08:23 PM
Sean @ ESG
10-16-2007 09:24 AM
