Oil capacity... after a head gasket change
Old 09-29-2017, 09:00 AM
soundquest's Avatar
Default Oil capacity... after a head gasket change
The owners manual calls for 3.5 quarts of oil for a standard oil and filter change... but I am wondering if anyone knows precisely (or roughly would work too) how much oil is required after doing an HG job with the oil loss coming from around the head itself and from the top engine. Thanks.
Old 09-29-2017, 09:03 AM
Chance EG's Avatar
Default Re: Oil capacity... after a head gasket change
Shouldn't be much different than what's quoted for a full oil/filter change, since the oil should have mostly drained back into the pan.
Maybe like 5-10 more ounces or something.
Old 09-29-2017, 09:55 AM
egsleepercivic's Avatar
The distance between the dots on the dipstick is one quart. add 3 quarts or so until you can see it on the dipstick, then go from there. I also usually put some oil in the filter too.
Old 09-29-2017, 10:15 AM
Chance EG's Avatar
I've always filled the oil up to the top line of the dipstick on Honda engines, then ran the car for 30 seconds or so to let the filter fill and the oil fill the system, then re-measure and add what's missing. Normally about 1/3 quart.
Whatever works. On larger engines though pre-filling the filter is a good idea.
Old 09-29-2017, 10:45 AM
soundquest's Avatar
Thanks guys.
Old 09-30-2017, 01:59 PM
Hysterically Calm
TomCat39's Avatar
Agreed, this was the must for the 1 liter diesel oil filters. By that, the filter held 1 full liter.
Never pre filled a car oil filter.
mrspeedy69
14
02-05-2012 11:48 AM
briq4
Honda Civic (2001 - 2005)
11
08-17-2009 04:30 PM
J.nguyen
10-14-2006 06:04 AM
Acco12dv6
10-02-2006 10:14 AM
Iomega01
03-25-2006 09:07 AM
Quick Reply: Oil capacity... after a head gasket change
