obdii catalytic converter bypass
Old 03-25-2009, 12:16 PM
j.orr's Avatar
Default obdii catalytic converter bypass
so i wanna remove my secondary O2 sensor and cat out from my exhaust system is there a way to get rid of the check engine light or bypass it??
please let me know
links would be appreciated also
Old 03-25-2009, 02:22 PM
Nichelson_Performance's Avatar
Default Re: obdii catalytic converter bypass
please let me know
convert to OBD 1 or punch the guts out of the stock cat, it did it before i was boosted and never had a CEL even still on OBD2
Old 03-25-2009, 03:05 PM
j.orr's Avatar
what do you mean by punch the guts out???
i dont wanna convert to obd1 until its turbo'd but i just completed my b16a2 swap and cant find a two wire secondary O2 sensor and off of my engine thats all its givin me is the connector for a two wire...So the four wire that came with my swap wont work and i cant get the two wire... will any secondary o2 sensor off a obdii work??
anyone
Old 03-25-2009, 03:19 PM
what i did, was i took a bar and and hammer and beat down through the honeycomb looking stuff inside the converter until it was all out, then all is left is a hollow shell. i'm still using it on my turbo setup.
i'm not sure if any 4 wire will work or not, i imagine the connectors are all the same on obd 2 cars so i can't see why it wouldn't work
Old 03-25-2009, 04:17 PM
j.orr's Avatar
I Do Not need a 4 wire secondary i NEED A 2 wire, thats all my motor has the wires for is a two wire, the wiring is from a 98 civic ex(SI canada)
j.orr
03-25-2009 09:25 PM
Nathavat
01-03-2007 10:22 AM
B!^A@
13
08-10-2006 06:26 PM
Hybridize
10-17-2003 01:56 PM
Ehron
09-19-2002 04:31 PM
Quick Reply: obdii catalytic converter bypass
