turbo tuning a obd2
Old May 10, 2004 | 06:40 PM
97dxnut's Avatar
Default turbo tuning a obd2
I'm thinking of turboing my y7. It's obd2 and i live in pa. I'd like to run 200-225 hp. It must be streetable, this being my daily driver. Starting this year, the emissions testing will include the tech hooking up a data link connector to the data port. This leads me to believe that i wont pass if i use a obd1 ecu to run hondata. This leads me to 2 possabilities.
1. Run the stock obd2 ecu. What kind of tuning can be accomplished? Will a apexi avc-r be enough to tune it?
2. Run an obd1 ecu w/hondata and swap the obd2 ecu in for emissions testing. What will happen to the stability of the system running with the stock ecu?
Old May 10, 2004 | 07:20 PM
scttydb411's Avatar
just swap back to stock inj and ecu effectively disabling/disconnecting hondata for the emissions test. make sure you open the wastegate all the way so you don't boost.
Old May 10, 2004 | 07:26 PM
97dxnut's Avatar
Default Re: (scttydb411)
By opening the wastegate, do you mean just remove the spring?
Old May 11, 2004 | 02:35 PM
97dxnut's Avatar
Default Re: (97dxnut)
bump
b16_swap
Engine Management and Tuning
Aug 20, 2009 06:50 PM
bsmith100
Jun 13, 2008 08:34 AM
b20izzle
Mar 4, 2006 07:09 PM
Mr. Em1
11
Dec 25, 2005 06:57 PM
luckypon7
May 24, 2003 07:00 PM
