obd2 motor in to obd1 del sol
i have a 93 del sol and im putting in a 98 b20 with b16 head. can i run an integra ls harness? im going to wire vtec to computer. what do i need to change to make it run. rather just change plugs on harness. thanks
Re: obd2 motor in to obd1 del sol
gsr harness prolly wont work, as it has stuff for the butterfly valves.
Have you looked at any of the b20 vtec writeups?
I would start by looking for a B16 harness from a 94 or 95 delsol VTEC model.
what B16 head are you using? as in what car/motor is it from?
any obd1, obd2a or obd2b engine harness from any b-series will work. The butterfly valves has its own 3 wire plug within the harness that will not plug into your shock tower harness. A ls harness will work fine, you just have to add 2 wires. One wire for vtec spool valve and the other for the vtec pressure switch. I hope you are going with a p28 chipped/tune. The p72 and p30 knock sensor control is useless for you. The reason being is the knock boards are calibrated for the b16a for p30 and the b18c for the p72. Therefore you can save some money by buying a p28 instead.
JDCB16Cx
02-26-2007 12:15 PM
