obd2 ex motor into 92 dx(already searched)
i already searched but could find the answer very eaisly...
what do i need to do extra, like do i need the whole obd2 wiring harness and ecu or can i just use my dx one and have to change the harness that plugs into the ecu or what??? can i get some help, thank you
Use your stock engine harness, there will be extra sensors on the block that might not plug into anything, ingore them. You'll have to get a p28 ecu and run the wires for vtec though.
Re: (Unsivil_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsivil_audio »</TD></TR><TR><TD CLASS="quote">Use your stock engine harness, there will be extra sensors on the block that might not plug into anything, ingore them. You'll have to get a p28 ecu and run the wires for vtec though.</TD></TR></TABLE>
So an OBDI engine harness will plug right up to the OBDII injectors, dizzy, and alternator?
1 Post
Re: (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">
So an OBDI engine harness will plug right up to the OBDII injectors, dizzy, and alternator?</TD></TR></TABLE>
you will need to use obd1 dist, alternator, injectors, there will be some plugs which you dont need to plug in.
veilsides2000
01-01-2005 09:17 AM
