B16a2 swap into 2000 Civic cx
Posts: Okay so I have a question about the wiring harness. I currently have a 2000 Civic cx hatch (obd2b) and am gonna swap a b16a2 into it wich is also obd2b I believe. Im wondering if I can use stock harness from the 99/00 b16 and plug it into a p2t ecu without problems? Thanks
Re: B16a2 swap into 2000 Civic cx
Use the si wiring harness. The ex will work as well, but you will have to extend some wires. The only thing that will give you problems is the secondary O2 wiring as it is on the engine harness for the cx and part of the body harness on the si. You can wire it up directly or switch out the body harness as well, but the latter choice takes a lot more work. The stock si ecu will be fine.
coupatroopa
11-02-2010 06:26 PM
^CX_d16
28
04-04-2005 04:15 PM
Tristan
12-30-2002 02:10 AM
