obd2 to obd1 harness?
Old Jan 9, 2003 | 12:20 AM
shawnc21's Avatar
Default obd2 to obd1 harness?
i have ran across a lot of talk on obd2 to obd1 conversion.. why would you want to use an older obd system? thanks
[Modified by shawnc21, 9:20 AM 1/9/2003]
Old Jan 9, 2003 | 12:25 AM
Cnote's Avatar
Default Re: obd2 to obd1 harness? (shawnc21)
ODB1 has less sensors to mess with and the ODB1 ecu's can be chipped. Not to mention you can us P28 as the ecu and get away with running an older/cheaper engine.
Old Jan 9, 2003 | 12:35 AM
SuperSH's Avatar
Default Re: obd2 to obd1 harness? (Cnote)
Also som OBD-2 vehicles cannot be re-chiped or reprogramed so your forced to convert to an OBD-1 to upgrade the ecu. Hince the conversion harness.
Old Jan 9, 2003 | 02:37 AM
TEAMGENDAI's Avatar
Default Re: obd2 to obd1 harness? (SuperSH)
alot less sensors plus chippable and hondata upgradable just alot more modication friendly.
Old Jan 9, 2003 | 08:16 AM
Tomei's Avatar
New User
OBD1 is simply cheaper & easier to re-program(simply dumb-er). It's not impossible to re-program OBD2.
Old Jan 9, 2003 | 11:21 AM
Civichatch2k's Avatar
Basically you can chip the ECU and it has less sensors that you have to mess with....Over all it is a easy way to help you car run a little harder.
novaslean
Apr 14, 2010 09:23 AM
egbaby
Mar 1, 2008 06:52 AM
NOman0608
Jul 26, 2007 10:28 AM
BLUE EH3
May 13, 2005 08:19 PM
Gmedalion
Jul 10, 2002 07:56 AM
