NOS questions???!!!!! anyone care to help?
ok heres the deal. i want to buy a used Nos kit for my car. How much will that be? 300? and what will i need to do for my car. i only want to run a small 50 shot or smoething. i have 93 civic. how muhc will proper installation cost and will i need to buy anything else for the nitrous kit? please only respond if you have the info i need. and if you ask why would i put nos in a 1.5 liter i really couldnt tell ya. i duess its the only thing i have to work with. i just like making things go faster then they should. should i get a dry kit or wet? which is easier to install?
Re: NOS questions???!!!!! anyone care to help? (redciviclx14)
May I recommend just buying a new kit. That way you know theres nothing really wrong with the used one. NOS could easily mess up your car if something was broken or worn away. So I suggest just buying the NOS, ZEX, or VENOM kits. ZEX is suppose to be really easy to install your self. The others should be easy also. Just follow instructions
i would advise against any NOS products. the kits are junk in my opinion. i like Nitrous Express stuff. i had a NX kit for a year and a half and know alot of people that have nothing but good experiences from NX. NOS kits come with tiny *** solenoids, the same size as NXs purge solenoids. NX kits come with the big solenoids that you normally pay extra for in a NOS kit.
when i sold my wet NX kit a while back, it went for $300.
the cost for a shop to install is going to vary and i dont know.
a 50 shot isnt too much to really worry about, but you could consider getting fuel pump thatll flow a little more. just keep stock ignition timing and check the plugs often to be safe. im assuming you run a stock ecu or maybe a chipped ecu.. either way for what youre doing id say run a wet shot just for reliability reasons.
start calling it nitrous, nawwsss will make you sound 2 fast 2 furious.
good luck.
good luck.
Re: (KillerWabbit)
alright so i can get a wet kit for about 300 and i would need to get a better pump. sounds good. i heard you should set your timing back 1 degree. thanks for all the NITROUS help!
mongoliandonuts
02-26-2005 02:09 PM
