extra high idle
Old Nov 29, 2006 | 06:28 PM
1sikhatch's Avatar
Default extra high idle
my car is idling hella high, at 6k rpm when i plug in the iacv when i plug it out it bounces between 1500 and 2k rpm, what is happening to my car?
Old Nov 29, 2006 | 06:43 PM
Shoob's Avatar
Default Re: extra high idle (1sikhatch)
mine too
Old Nov 29, 2006 | 08:22 PM
cranny's Avatar
24.224.233.247
Default Re: extra high idle (Shoob)
did you say it idles at 6000 rpm? lol. sounds like your iacv is more than leaking , lol. i wouldnt think your iacv could let enough air in to make the car idle that high. your telling me you have no engine light at all when this is happening , lol? ive never seen a honda idle at 6000 rpm , lol , and ive been working on cars for over 15 years. thats a good one.
Old Nov 29, 2006 | 09:19 PM
IntegraDOHCter's Avatar
Mines been idling weird too. It idles fine after its warmed up,I'll be driving along,and come to a stop or push in the clutch,the idel drops down to normal,than goesb ack up to 1500 or so? wtf? Its annoying and burns gas up
Old Nov 30, 2006 | 12:12 AM
alexisthemovie's Avatar
Default Re: (sloJRSCLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloJRSCLS &raquo;</TD></TR><TR><TD CLASS="quote">Mines been idling weird too. It idles fine after its warmed up,I'll be driving along,and come to a stop or push in the clutch,the idel drops down to normal,than goesb ack up to 1500 or so? wtf? Its annoying and burns gas up</TD></TR></TABLE>
mine does the same thing. idles at about 1500 when cold and around 800-1000 when heated up. sometimes a good stoplight rev will mend it, sometimes not.
Old Nov 30, 2006 | 12:25 AM
HandleTech's Avatar
Vehicle info would be of a help
But it sounds like it could be a vaccum leak, bad
program, IAC or something else along those lines.
Have you ever tried cleaning your throttle body?
Use a toothbrush and some chem-tool spray and scrub the inside
while the cars off and the throttle is wide open.
After your satisfied with how clean it is, be sure to hold the gas pedal
wide open and crank until the car starts and sounds normal (no stuttering)
to clear out any spray and/or carbon. HOpe this helps...
Old Nov 30, 2006 | 01:15 AM
99Geeezer's Avatar
model and year? any codes?
Old Nov 30, 2006 | 04:05 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: extra high idle (99Geeezer)
clean your idle air control valve, just remove it. and brake cleaner the **** out of it. also you might want to check the TPS
Old Nov 30, 2006 | 04:09 AM
1sikhatch's Avatar
Default Re: extra high idle (god.loves.ugly)
its a 95 gsr, no codes.
i cleaned the iacv, still does it
changed the iacv to one i know is working still does it
tps is good
tb is clean
checked all vacuums and their nice and secure
Old Nov 30, 2006 | 04:10 AM
god.loves.ugly
Guest
Posts: n/a
days it stay high even after driving for a while?
my tps is not adjust correctly and mine idles really high when i first start it... I mean like 2k and then once it gets warm it drops a little...
Old Nov 30, 2006 | 04:35 AM
cranny's Avatar
24.224.233.247
for all you guys that have high idles that dont bounce , its most likely a PCV valve or vacuum leak like a cracked line or missing.
Old Nov 30, 2006 | 09:55 AM
Default Re: (alexisthemovie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie &raquo;</TD></TR><TR><TD CLASS="quote">
mine does the same thing. idles at about 1500 when cold and around 800-1000 when heated up. sometimes a good stoplight rev will mend it, sometimes not.</TD></TR></TABLE>
Thanks I'll try that...looks like from your sig I'm running a similar setup...LS...
kitt
Apr 29, 2010 11:57 AM
bdubnyc
11
Apr 18, 2008 09:39 PM
Paprika
May 8, 2007 03:18 PM
93JDMB18C
Nov 2, 2006 02:03 PM
TheNasty0ne
Dec 17, 2005 01:07 PM
