Quick coolant questions...did search
Old Oct 13, 2007 | 08:04 AM
Urugly's Avatar
Default Quick coolant questions...did search
When I did search all I get is problems with coolant or coolant mix with oil..etc..etc..
My question:
for FI cars...what coolant are you guys using..
Brand
50/50 premix
All coolant w/NO water added
What's best for our cars.... I am about to go buy some..
Thanks guys.
Old Oct 13, 2007 | 10:47 AM
kyle3838's Avatar
Default Re: Quick coolant questions...did search (Urugly)
i just use the 50/50 mix
Old Oct 13, 2007 | 09:35 PM
usmarinedelta's Avatar
* B A N N E D *
what you don't want is all coolant, that's no good, your car would overheat, the purpose of coolant is to antifreeze your car, it raises the boiling point in water BUT water cools way much better than coolant however too much water can cause your car harder to heat up so longer till boost what I use is 30% coolant and 70% water. Distilled water in a gallon jug at supermarkets that is.
Old Oct 14, 2007 | 07:55 AM
a1320addict's Avatar
Default Re: (usmarinedelta)
OEM Honda..pre-mixed...and looks nice
Old Oct 14, 2007 | 09:24 AM
Urugly's Avatar
thanks for the response. I just didn't know. I bet people like myself get the perception that coolant/antifreeze only is better, but actually it is the opposite like you said. The water agent is what cools it more.
I got the Prestone 50/50 and I added water wetter to it. I think it helped a bit.
Thanks.
Old Oct 14, 2007 | 05:39 PM
TurboEM1's Avatar
Default Re: (Urugly)
50/50 Prestone Premix
An extra splash of bottled water.
A bottle of water wetter
Old Oct 15, 2007 | 01:45 PM
meowpox's Avatar
Default Re: (TurboEM1)
the more water you have in your coolant system, the cooler it will run. you need some coolant to lubricate the water pump though. i run 90% water and the rest water wetter. works well for me. i dont use coolant because it doesnt get cold enough here in california to freeze the water.
dth0ng69
18
Jul 19, 2009 09:12 AM
SpoonIntegra808
Oct 21, 2004 05:04 AM
99bb6
10
Sep 23, 2004 08:36 PM
rated_r
May 12, 2004 07:45 PM
TurBoXBirD16
11
Mar 20, 2003 01:55 PM
