Coolant Mix
Coolant Mix
How much do you mix your coolant with water??
50%? 70% of coolant??
thanks
edit : wow i hit 1700 posts !
[Modified by TurBoXBirD16, 7:33 PM 3/19/2003]
thanks
Re: Coolant Mix (TurBoXBirD16)
It really depends on the climate you're in. For example, in Cali where we hardly see below 40 degrees in the winter and well over 90 degrees in the summer, its good to have 80-90% water and 10-20% coolant. For colder weather its better to have more coolant, but remember, its the water that does most of the cooling, the coolant keeps it from freezing and boiling.
Re: Coolant Mix (SanoJDm)
this is not a good idea because the water alone will deteroate(sp?) the aluminium.
