Weird problem
Weird problem
Ok when the car is cold, and i drive it normal, i hit the gas and it goes for a min then louses power, bu dose not die and drops back, and gains power again, and then drops back again, until it gets warm or i punch the gas, any help?
Re: Weird problem (Exploziveaf1)
did you mess with the idle screw, if so put it back the way it was. maybe be something with vacume also. friend had this problem and i fix the screw and drives normal. i think the ecu has something to do with recognizing it.
Re: Weird problem (Dickies_N_FlipFlops)
i did replace the head, but it was doing it before i took off the throttle wire. but not as bad but it did have a low idel so ill check it
prendi
20
04-14-2003 01:51 PM
