need a tip for popping in axle
i did my swap drove it for a day and my axle popped out not completly but enough to were it wont drive and with the axle being hooked to the wheel i can only get it to about the same spot but it wont lock in and tips my one friend was saying we could undo the main bolt on the wheel side and smack it with a hammer to get it set in..
Re: need a tip for popping in axle (c1civic)
I would take axle out and try re-installing it.
https://honda-tech.com/zerothread?id=382416
Check out this thread, it should help you understand more on what to do.
Unceasing Measure
Re: need a tip for popping in axle (junglerunna02)
No hitting the axle with a hammer. Ever. Take it all the way apart (suspension too if it's required) and do it all over. Trust me, the annoyance of a repeat install is better than stripping the splines off an improperly installed CV shaft .
it was in good shape before i mean the only thing that happened is it didnt click i am guessing when my dad installed it and it is in the tranny a lil bit right now but it needs to click so it is set right just need a lil more umph to get it to click
Unceasing Measure
Re: (c1civic)
wiggle and push, wiggle and push and twist until that bastage buddies up to the case . It's always an annoyance, but it's one of the most important parts and that's why I insist on doing the axles on every swap I've ever helped with. No pop-outs yet .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic »</TD></TR><TR><TD CLASS="quote">my one friend was saying we could undo the main bolt on the wheel side and smack it with a hammer to get it set in..</TD></TR></TABLE>
BFH
BFH
Re: need a tip for popping in axle (DaX)
Get a 2x4 piece of wood, and tap the cv joint in until it snaps right in. Do not use a hammer on the CV joint, and I do not recommend hitting it directly on the other end.
You shouldn't need a hammer. Just take the suspension apart again and take the axle all the way out, then put it back in. Grab the joint that goes into the tranny with your hands and just keep pushing on it. It will take some force, but you should know when it is in. If you aren't sure try pulling it out and if you can get it out without a pry bar, then it isn't in all the way.
