Need program for p06 to run a b20
Re: (thinkbrianthink v2)
Are you trying to do a B20/V?
I thought the best one for you would be a p28 chipped, but after reading on HT, it seems as people are using this ECU. Not sure if you are going to chip it or not, but I read if you use the stock program it will lean out in high RPMs which could be dangerous.
No vtec. Just the stock motor.
Im looking for a program/base map that will run as close to stock specs as possible. Is it possible to just chip an ECU with another ECU's specs?
I already have an safc2 for tuning.
I guess you would be alright, not sure though. Read up on HT they have a few threads concerning the p06.
Actually I just searched again and there isn't much to read on, maybe someone who knows alot about ECUs will post.
