need to know which injector is which
i have a D16 engine and i am wiring it up right now and i need to know how i can tell which is injector #1, #2, etc.
i couldnt find anything when i searched... which is which?
Re: need to know which injector is which (ace1875)
but wouldn't that mess up the order if they were in the wrong spot... can the ECU tell where each injector is??
by the way, i have a CRX.. wrong fourm.. mod you can move this if you want.
Re: need to know which injector is which (filthyCREX)
**** i thought you were taking about the injector not the injector wring. You should have said, "which wire plugs in which injector" on me.
let me look it up.
let me look it up.
i am talkin about the actual injectors... i already found the wiring... i need to know which is which in the actual engine tho
like which one does red connect to? (ex: 2nd from driver's side, or 2nd from pass side)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthyCREX »</TD></TR><TR><TD CLASS="quote">like which one does red connect to? (ex: 2nd from driver's side, or 2nd from pass side)</TD></TR></TABLE>
Number 2 is 2nd from timing belt. It goes in order from the timing belt side to the tranny side.
Re: need to know which injector is which (TeStUdO)
alright cool so i have it right!
can someone help me out with my distributor problem... here is my post: https://honda-tech.com/zerothread?id=687988
