Need Info asap
b16a help
I have a 1996 honda civic ex, and i recently dropped a 1994 civic si complete b16a JDM swap into my car. Car starts, wiring is complete, but half shaft and bracket don't fit flush against the block. I bought the right half shaft, but it still wouldn't fit. What should i do? should i buy a different half shaft. Also i heard you can use intergra half shafts and axle. Any reccomendations or tips
Modified by importeuros at 9:37 PM 1/10/2008
H-T White Ops
Re: Need Info asap (importeuros)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importeuros »</TD></TR><TR><TD CLASS="quote">I have a 1996 honda civic ex, and i recently dropped a 1994 civic si complete b16a JDM swap into my car. Car starts, wiring is complete, but half shaft and bracket don't fit flush against the block. I bought the right half shaft, but it still wouldn't fit. What should i do? should i buy a different half shaft. Also i heard you can use intergra half shafts and axle. Any reccomendations or tips</TD></TR></TABLE>
FYI, the '94 Civic Si does not have a JDM B16A. It has a D16Z6.
Re: Need Info asap (NOFX)
well i have been told that the engine was from a 94 si but in the us they were only found in the del sols. and what year integra?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importeuros »</TD></TR><TR><TD CLASS="quote">well i have been told that the engine was from a 94 si but in the us they were only found in the del sols. and what year integra?</TD></TR></TABLE>
94-01 integra parts will fitand does it stamp DOHC VTEC on your valve cover and alos b16a3 stamp on the engine block ?
USDM 94 civic si comes with single cam vtec D16Z6 engine
Re: Need Info asap (crazyguy)
i heard that it was off a 94 civic in japan. and at that time the only honda in the US with the b16 engine was the del sol. but i still would like to know why the DOHC half shaft wont fit to the block.
well what kinda tranny u got? cable trannies have different half shafts other wise try a teg one. it should go right in..r u putting the axle in right?
=ITRpoweredEK9=
12-29-2005 06:22 AM
supaman111
08-02-2005 10:00 AM
etp72
04-21-2005 12:24 PM
JDM knowledge
02-22-2004 07:21 AM
