Need help with suspension part....
I'm missing the piece of rubber that goes there... I know I can get it from honda, but does anyone know if Energy Suspension makes a replacement for it???
Re: Need help with suspension part.... (EVIL Hx Coupe)
Looks like something went horribly wrong there. O_o
FWIW, Koni doesn't advise the use of urethane bushings for the top hats (even voids the warranty of their shocks) because they don't reduce vibration enough and it travels through the shock rod and ***** **** up, IIRC.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Are you wondering if the Energy Suspension one is cheaper? If not, the urethane bushing up there won't do ****, so just get a stock one.</TD></TR></TABLE>
I was just wondering if would improve anything... I't only 7 something at honda for the top one, bottom one and the little rod that goes in the middle....
Thanks for the answers..
Re: (EVIL Hx Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe »</TD></TR><TR><TD CLASS="quote">
I was just wondering if would improve anything... I't only 7 something at honda for the top one, bottom one and the little rod that goes in the middle.... </TD></TR></TABLE>
Hmm, sounds like ya put the damper together incorrectly.
How did you assemble it?
You want to put the following on the strut rod in order:
- bump stop (cut in half)
- rod washer (that goes to the thin part of the stem)
- then there should be some rubber bushing, or metal piece with a rubber gasket type (depends on the suspension, I am not sure what yours came with). Honda has a thick rubber bushing that goes inside the hat part of the damper.
- rubber bushing (like you are describing in the picture), only that goes UNDERNEATH the damper hat
- then that bushing you are missing in the picture
- washer on top of that bushing
- damper nut that compresses the bushings.
make sure ya put it together in the right order, otherwise it could cause some serious damage when rolling around.
Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
Sir you are my hero... Now I know what I'm missing.. I forgot to put this, and now I remember I threw it away not knowing what it was ... Where can I buy this???
Re: (EVIL Hx Coupe)
Sir you are my hero... Now I know what I'm missing.. I forgot to put this, and now I remember I threw it away not knowing what it was ... Where can I buy this??? </TD></TR></TABLE>
Here is a better picture for ya:
and the link:
http://www.hondaautomotivepart...ORBER
The part you quoted that I was referring to is part number 9 on that diagram.
and the link:
Re: (EVIL Hx Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe »</TD></TR><TR><TD CLASS="quote">I got it like that...
Whats the rubber thing on top of this coilover for?? </TD></TR></TABLE>
The red one?
That goes on top of the spring UNDERNEATH the top damper hat.
The red one?
Re: (poison)
The red one?
That goes on top of the spring UNDERNEATH the top damper hat.</TD></TR></TABLE>
So without this my suspension wont sit correctly right?
The red one?
Re: (EVIL Hx Coupe)
So without this my suspension wont sit correctly right? </TD></TR></TABLE>
Without this, the spring will sit right on the damper hat base (part #7) and could damage.
I would definitely not run with out it.
Re: (poison)
crap ... I been running without it for two months... I'll see if I can find the ones I was using with my old coilovers... Do you know where I can buy just the red part for the top of the coilovers???
Re: (EVIL Hx Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe »</TD></TR><TR><TD CLASS="quote">crap ... I been running without it for two months... I'll see if I can find the ones I was using with my old coilovers... Do you know where I can buy just the red part for the top of the coilovers???</TD></TR></TABLE>
You can run the stock HX ones if you still have them (and provided they are in decent condition), otherwise, I would probably contact some suspension companies and ask them if they have any upper spring bushings that go under neath the damper base hat.
I am pretty sure many of them carry them. And most of them will work.
Re: (SlippylesKB)
If you need the rubber piece that goes between the spring and the shock top hat, I have 2 extra rubber ones from Ground-Control, they have about 2 miles on them and fit perfectly under the stock O.E. shock top hats.
I also have extra Ground-Control metal tube things that go inside the the 2 rubber bushings inside the top hat that slides over the shock piston ride.
And i also have NEW Honda O.E. rubber bushings that go in the top hat. One above in the top hat, and one below, I have 4 total (for the fronts). They have about 2 miles on them.
I also have the washers that goes ontop of those bushings too, that slides on to the shock piston rod ontop of the shock top hat assembly.
If you need any of these parts, just PM me.
fryman
Suspension & Brakes
24
12-08-2009 10:07 PM
