need help surging issue
need help!! surging issue
already replaced the following parts:
coolant temperature sensor(new)
throttle body w/ map,tps,icv(used)
tune up stuff:fuel filter,spark plugs,etc.
throw me some ideas car gods pls...
the car is 96 civic hb w/d16y7
Re: need help surging issue (mg40)
Clean the used IACV and bleed the cooling system of trapped air.
If still no satisfaction, check for vacuum/intake air leaks. Look for loose or disconnected hoses leading to the intake manifold. Spray carb cleaner around connections and gaskets while engine is idling -- a change in idle speed would indicate a leak.
liljukmoves
18
06-26-2011 07:18 AM
asianrepnsb
12
03-08-2008 12:26 PM
