need help surging issue
need help!! surging issue
already replaced the following parts: coolant temperature sensor(new) throttle body w/ map,tps,icv(used) tune up stuff:fuel filter,spark plugs,etc. throw me some ideas car gods pls... the car is 96 civic hb w/d16y7 |
Re: need help surging issue (mg40)
Clean the used IACV and bleed the cooling system of trapped air.
If still no satisfaction, check for vacuum/intake air leaks. Look for loose or disconnected hoses leading to the intake manifold. Spray carb cleaner around connections and gaskets while engine is idling -- a change in idle speed would indicate a leak. |
Re: need help surging issue (RonJ@HT)
will do tomorrow thank u
