NEED HELP WITH KILL SWITCH ASAP
Old 10-14-2009, 09:53 PM
LaOXXKIDD's Avatar
Default NEED HELP WITH KILL SWITCH ASAP
i did everthing right but when i tryed to ground the switch it stoped working
Old 10-14-2009, 11:26 PM
denraweb's Avatar
Default Re: NEED HELP WITH KILL SWITCH ASAP
Why would you ground the switch? How did you wire up your switch?
All i do is take the power wire to the fuel pump, cut it, then put one end of the wire on one terminal on the switch, and the other end of the wire to the other terminal. So in order to complete the circuit for the power to the fuel pump, you have to flip the switch. Is this what you did?
Also be careful if you're doing a fuel kill switch, you could fry your whole fuel harness or your fuel pump
Old 10-14-2009, 11:37 PM
Linked's Avatar
LMAO, you do not ground the wire....
you simply put a switch in the wire so it does not connect when in one position, and is connected in the other
its EXACTLY LIKE THIS, except the battery is one end of the split fuel pump wire, and the car is the other end of the fuel pump wire
the middle pin goes NO WHERE
it willbe like this ... : wire ----> switch <---- wire
Old 10-15-2009, 10:13 AM
LaOXXKIDD's Avatar
lol i ment like to make the light switch turn on. but i found out what was wrong. it was a blown fuse
Old 10-15-2009, 11:42 AM
civic_r87111's Avatar
WOW, what amperage switch r u guys using?
Civic Si Kid
Audio / Security / Video
05-17-2009 12:26 PM
Ldo
10
02-24-2009 05:15 PM
96electronH
12-02-2007 05:29 PM
99fbpem1
08-19-2007 04:23 PM
StreetRacnGsR
23
06-18-2003 05:05 AM
Quick Reply: NEED HELP WITH KILL SWITCH ASAP
