fuel kill switch....
Old Dec 1, 2007 | 06:29 PM
96electronH's Avatar
Default fuel kill switch....
i want to install a kill switch for my fuel pump on my 96 civic ex and i read up on it and found out about the yellow/green wire that you put the switch to to control the fuel pump...
but wouldnt that mean if you did hook the switch right to the wire and you accidentally left it on after turning your car off it would keep the fuel pump on??
And is that what the relays are for??
Old Dec 1, 2007 | 08:26 PM
ek4shizzle's Avatar
Default Re: fuel kill switch.... (96electronH)
no if you left the switch on fuel would not be pumping. thats only if you hooked the switch up with power. cut the yel/grn wire and wire each side to both sides of the switch.
Old Dec 2, 2007 | 03:39 AM
supracrx's Avatar
to the wire power is received only when ignition is on....its not a constant 12v going to the pump.
that wire only receives power when u turn on the ignition....its not a constant power wire
Old Dec 2, 2007 | 05:29 PM
thnaks guys kill siwtch is hidden and works like a charm thanks for info
LaOXXKIDD
Oct 15, 2009 11:42 AM
turbo-crx
Jan 9, 2009 09:58 AM
99fbpem1
Audio / Security / Video
Aug 19, 2007 04:23 PM
StreetRacnGsR
23
Jun 18, 2003 05:05 AM
Aphrodavid
Feb 19, 2002 06:56 AM
