NEED HELP install on SI cluster on 97 hatch *searched*
Was helping a friend install the cluster but could not find the wires for the tach, is there something Im missing? thnx
Re: NEED HELP install on SI cluster on 97 hatch *searched* (tegedrex)
was is civic a 96-00 cx, if so i think they don't have the wires for the tach. You might have to wire it from ecu to the plug.
Re: NEED HELP install on SI cluster on 97 hatch *searched* (sebmour jdm)
The cx and dx are both wired for the tach, even though neither come with it. You should just be able to plug it in and be good.
Re: NEED HELP install on SI cluster on 97 hatch *searched* (O.G triple O.G)
thats what Im trying to say there is not Tach plug, I searched around for it but came up with nothing, could it be hiding somewhere
it already wired in the harness. no need to add or tap anything.
im not too familiar with 96+ but i believe you just pull out the 3 4 plugs they have
behind the factory cluster and plugs it up to the Si cluster.
theres no separate plug . the wire will be within the two plugs you already have... the tach wire will be i think the solid blue wire.. at least it is with the 92-95 civics.
unplug the 3 plugs on the stock cluster. plug them into the si cluster. THERE IS NO TACH WIRE, IT IS ALAREADY IN THE HARNESS, JUST PLUG THE 3 PLUGS IN AND BAM YOUR DONE
Re: NEED HELP install on SI cluster on 97 hatch *searched* (tyflip2)
I think I found the problem right know there is an monster tach in the car the person who installed it before must have just took this blue wires an ran it off that.
Thnx
Thnx
yeah...just plug those 3 harnesses into the cluster....
the yellow plug on the back if for cruise control which that car does not nor will ever have.
if the guy has a monster tach, he should've tapped the wires not cut them off completely
Re: NEED HELP install on SI cluster on 97 hatch *searched* (JUN EK9)
I just put the si cluster in my 96 civic dx and it went with no problems, just plug in all the existing harnesses. My tach works along with all the rest of the cluster.
Re: NEED HELP install on SI cluster on 97 hatch *searched* (streetlvlhatch)
it should plug right in.....i didn't have no problems.with my 2000 cx hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlvlhatch »</TD></TR><TR><TD CLASS="quote">I just put the si cluster in my 96 civic dx and it went with no problems, just plug in all the existing harnesses. My tach works along with all the rest of the cluster.</TD></TR></TABLE>
I'm picking up a 96 Cx in the morning. I think the Si cluster will be my first mod
Re: NEED HELP install on SI cluster on 97 hatch *searched* (Hybrid93Hatch)
The 3 harness plugs that you took off your stock cluster will be the only three plugs you put in your new cluster. Don't worry about anything else on the harness or the new cluster.
Filliam H. Muffman
10
12-13-2002 09:51 PM
