Tach install with new Si cluster
im getting an Si cluster for my 6th gen hatch...and i dont have a tach on my current cluster...is it just plug and play...or does it need modification?
Re: Tach install with new Si cluster (ElectronBlueGSR)
it should take you about 5 minutes. its a simple plug and play mod. There are 2 screws holding on the bezel, just unscrew those and pull out the bezel, then there is 4 screw holding in the clusters just take those out and and unplug your cluster. Then plug in the si cluster and put it all together again.
Re: Tach install with new Si cluster (JUN EK9)
make sure you change the fuel gauge to show how much fuel you have in your car, or else it will be inaccurate.
Re: Tach install with new Si cluster (tominos)
the gauge will read it correctly.. plug and play.
Nocturnal
08-31-2003 07:37 PM
