need help instaling a tac into 95 cx
Re: need help instaling a tac into 95 cx (RabbittZ)
ok, this will be everything.
black wire- ground somewhere, be sure to scrape paint first
red wire- attach female plug thing (forgot what its called, youll get it in the box) run dwon to fuse box, and plug into the far right plug, over top of the regular fuses (theres 5 little plug looking things, just stick the female plug onto it)
white wire- same as red, but plug into second from the right plug, so the white and red wired will be right next to eachother.
green (or is it blue?) wire- run to the distributor, and splice on the blue wire thats on the plug that has 2 wires. you can connect it to the blue wire on the drivers side strut tower, but i found it was MUCH less responsive.
good luck!!
oh yeah, and seacrh before you ask this stuff, its all somewhere on this site.
good luck!!
Re: need help instaling a tac into 95 cx (leprechan117)
yeah.. i never come up with a good search.. no luck here.. but yeah.. are you talking the blue wire coming out of the dizzy??? if so, youve been a lot of help.. thanks man.. ill try and see what your talking about.. and then if anything ill I.M. you.. but anyone else .. throw up some help too.. thanks !
cool thanks dude.. ill try that out and let you know how it worked.. what did you do about hiding the wires???
the only wire that you need to hide is the green one, that goes to the dizzy, since the other 3 dont leave under the dash. i just used electricval tape, and taped the wire to the wire looms that were already there, you cant see it at all.
Kyles ej1
09-26-2004 11:58 AM
