Need help identifying JRSC fitment
Can anyone tell me what Honda D series motor my JRSC was designed for?
The bolt pattern appears to be for a D16Y7, Y8 or SC, but the manifold flange is flat across the top and extended with what appears to be a 2nd gasket imprint above the manifold gasket. I cannot find another picture of one that has this feature. The upper gasket has holes drilled through to the injector holes and there is a casting added with a vacuum fitting at the top, in the center area.
Re: Need help identifying JRSC fitment
The '96-00 Civic D-series JRSC kits use the same intake manifold... the one you have pictured appears to have been installed on a '99-00 Civic because the newer cylinder head uses the vacuum accumulator rail across the top of the intake ports and merges it to the brass fitting pointing straight up on the top of the intake manifold. If you are using it on a '96-98 D-series cylinder head, simply use the stock type gasket with the manifold and you will be fine. To clean up the install, remove the brass fitting on top and plug the hole.
What is "high boost" and "large turbos" to you?
You crack me up...you think a supercharger is capable of producing the same amount of psi as a turbocharger? A supercharger on 30+ psi hehe. Your funny
talks to himself
project dc2
08-03-2005 05:26 AM
