need help eliminating srs light with personal wheel
i have a personal wheel that i am going to install in my 00 civic dx. Id like to know how to get rid of srs light and wire the horn. If anybody can help i would appreciate it. Thanks in advance......
Re: need help eliminating srs light with personal wheel
You are gonna have to unplug the connector for the SRS unit in the back of the cluster. I think it's the 2-pin, yellow plug. For the horn, get a tab piece off a CRX or DA Integra and wire it up, some people use pen clips also. There are a few threads about it on here.
Should be a yellow jumper plug sitting by the fuse box. Jump the pins with a wire and you have to do a certain key turning sequence.
this only works to reset the srs system to remove a light but it will pop right back on once the system doesn't see the airbag plugged in for the steering wheel what i did on my civic was unplugged the srs harness from the rear of the cluster there for it never receives the signal to turn on the light
There's a write up on it somewhere its in my favorites on my comp ill post in the morning im on my phone now....it shows the exact resistor to use as a jumper for the srs plug so your light stays off and your passenger bag still works.
indeed there is a writeup :p
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-bypass-srs-aftermarket-wheel-2398113/
ITR010342
05-08-2009 08:27 AM
servion
01-14-2002 01:54 PM
