crankshaft flucuation sensor help!!!
i have a 98 ex civic with a 99 gsr swap...im using the obd2a p72 ecu....well im getting the crank flucuation sensor code. when i look at the crank, i see a plug thats not plugged into anything...im curious to where the damn thing plugs into...i want my car running normal again. any help would be greatly appreciated...thanks!!
Re: crankshaft flucuation sensor help!!!
It plugs into the engine harness. Also you can bypass the sensor.
http://www.ff-squad.com/technet/ckftrick.htm
ok i see. i appreciate it alot. i looked on the harness and didnt see an plug hanging down that could possibly plug into the sensor
ok i see it now. the ex harness is a 3 wire, and the gsr is a 2 wire...so can i just get some extra wire and connect the 2 matching wires up and it be good? i believe its white/red and blue/red....im guessing the orange/black is just a ground
Bjm1118
03-12-2019 04:58 AM
