need help with b16 swap into 96 civic ex any help is good
i need to know if i need all the mounts from the 99-00 si or do i just need certain ones cause different people have told me different things and also will the ac compressor from my d16z7 work and also will the power steering pump work any help would be appreciated
[IMG][/IMG]
[IMG][/IMG]
Re: need help with b16 swap into 96 civic ex any help is good (kreativekustoms)
you can use 99-00 si mounts actually you need the rear bracket, 2 front brackets. use a 95 delsol vtec p54 a/c bracket and retain your a/c compressor. Use your stock upper mounts on driver and tranny side.
esurds
07-09-2009 05:50 PM
