Need help with B16 LSD Install.......
Old 01-12-2009, 10:48 AM
1baddcivicsi's Avatar
Default Need help with B16 LSD Install.......
I got a JDM CTR LSD, i purchased a GSR Ring Gear for the Diff & the tranny shop called me & told me that theres a 5mm difference in the height from the b16 & the b18 GSR ring gear.
What do i need to do?
Old 01-12-2009, 01:12 PM
Default Re: Need help with B16 LSD Install.......
Nevermind, i misunderstood what the tranny shop told me. GSR RING GEAR IS FINE.
Old 01-12-2009, 01:16 PM
The problem is: the stock differential has a raised lip, when the bear is pressed on it fits perfectly, but the JDM CTR LSD has NO LIP WHAT SO EVER, when the bearing is pressed on the LSD, it rubs on the tranny case. 5mm is the difference. I dunno, i will post pics in about an hour or so......
Old 01-12-2009, 03:06 PM
Endo-land's Avatar
B16a and b18b use the same diff and tranny casing. B16b and b18cx use the same. You may need a different lsd or get a gsr casing for your gear set.
Old 01-12-2009, 05:06 PM
This picture is the stock carrier with the raised lip around the center.
Old 01-12-2009, 05:07 PM
This picture is the JDM CTR LSD, with no raised lip around the center
Old 01-12-2009, 05:10 PM
This picture is the inside of the case, where the shop went to install the LSD, but it rubs on the case.
Old 01-12-2009, 05:12 PM
The shop reccomended puting a shim between the speedo gear & the bearing
Lemme know what u think i should do, i dunno
Old 01-12-2009, 07:55 PM
so. I need to install a shim, how do i do that? or how does that work?
Ti3d in
Transmission & Drivetrain
03-16-2009 02:46 PM
1baddcivicsi
01-12-2009 06:08 PM
1EG2NV
09-04-2008 02:53 PM
JdmTosca
08-18-2008 02:28 PM
Quick Reply: Need help with B16 LSD Install.......
