help with o2 sensor issue
Old Nov 18, 2002 | 12:35 PM
EVOCELICA's Avatar
New User
Default help with o2 sensor issue
I am getting a CEL it throws a 1 code which is primary o2 sensor, I went ahead and replaced the o2 sensor but I still keep getting the CEL, anyone have any advice on what i should do next, this is on a 90 civic with a pr3 computer and a b16. Also the CEL comes on and stays on even before i start the car, i've un hooked the battery and the ecu and then conected everything after installing the new o2 sensor and it still throws a code. please help.
Old Nov 18, 2002 | 12:38 PM
Desslok's Avatar
Default Re: help with o2 sensor issue (EVOCELICA)
Get your battery tested. THe same thing happened to me and it ended up being the battery.
Old Nov 18, 2002 | 12:45 PM
EVOCELICA's Avatar
New User
Default Re: help with o2 sensor issue (sp)
How could it be the battery? I don't see the logic
Old Nov 18, 2002 | 12:49 PM
Desslok's Avatar
I didn't either, but that's what it was, after I replaced the o2 sensor. I guess the o2 sensor wasn't getting enough voltage and the ECU saw it as a bad signal? Just trying to help.
Old Nov 18, 2002 | 12:51 PM
EVOCELICA's Avatar
New User
see your point but the motor cranks over just fine and it even starts, but just runs shitty
Old Nov 18, 2002 | 02:20 PM
Desslok's Avatar
That's what mine did, too.
Old Nov 18, 2002 | 08:58 PM
EVOCELICA's Avatar
New User
anyone else have an idea
Old Nov 18, 2002 | 09:21 PM
salbaje's Avatar
check wiring
Old Nov 19, 2002 | 06:18 AM
Crazydave's Avatar
Default Re: help with o2 sensor issue (salbaje)
make sure you dont' have any exhaust leaks...
Old Nov 19, 2002 | 11:21 AM
Leb_CRX's Avatar
Default Re: help with o2 sensor issue (Crazydave)
here's the main things to check before you go ahead and change your battery, I really dont see the logic behind that...but who knows sometimes things dont have logic
could be fuel pressure...swap your fuel pressure regulator
check the ground on the thermostat housing...
those are the two main things
|eb_CRX
Old Nov 19, 2002 | 11:33 AM
EVOCELICA's Avatar
New User
Default Re: help with o2 sensor issue (Leb_CRX)
why would it be the fpr?
Old Nov 19, 2002 | 11:51 AM
EVOCELICA's Avatar
New User
battery is less than 2 months old and i just checked it, 11.83 volts. is the o2 wire supposed to have power running thru it, how does the ECU know to throw a code is it when voltage drops?
Old Nov 19, 2002 | 01:05 PM
Leb_CRX's Avatar
not shure...just one of them things, the o2 gives reading as to how it's burning, maybe it's reading too much fuel, triggering a code...honestly I am not shure but I know it has something to do with throwing code1 sometimes
|eb_CRX
Old Nov 19, 2002 | 01:07 PM
Leb_CRX's Avatar
no the O2 has no power running through it...it 'creates' (bad choice of words, I know) power ranging between 0-1volts and returns it to ECU....well if the o2 is not sending anything back it's clearly dead, flags it as a code1
check the thermostat ground
|eb_CRX
Old Nov 19, 2002 | 01:13 PM
EVOCELICA's Avatar
New User
are you talking about a ground strap?
Old Nov 19, 2002 | 01:22 PM
Desslok's Avatar
A good battery at rest should have about 12.66 VOlts, if it is only 2 months old and it only has 11.8 volts, there is either a problem with the battery, alternator, or ground. And a 4 wire O2 sensor does have power going to it for the heater.
Old Nov 19, 2002 | 01:43 PM
sgT's Avatar
sgT
do you have BOTH o2 sensors installed and wired properly??
Old Nov 19, 2002 | 02:31 PM
Blaze45's Avatar
Brrraaaap!
Default Re: help with o2 sensor issue (sgT)
it could possibly a problem if you have a A/F gauge. My car does the exact same thing. The A/F gauge is taking the 1 volt required to send the message to the ECU.
Good Luck.
Blaze
Old Nov 19, 2002 | 02:37 PM
tinkerbell's Avatar
did you replace the right sensor? maybe you repalced the secondary O2 sensor?
how did you tell the two appart???
t..
Old Nov 19, 2002 | 04:04 PM
EVOCELICA's Avatar
New User
Default Re: help with o2 sensor issue (tinkerbell)
i replaced the first 1st o2 from the manifold, just thinking that it was the wrong one i switched the wires to make sure, also the battery was at 11.8 something volts with the car not running, i start it and it reads about 13 volts. I don't have a a/f ratio gauge so i don't see that as being a problem. This happened after I did the ITR manifold swap, if that has anything to do with it.
Old Nov 19, 2002 | 04:15 PM
tinkerbell's Avatar
so you swaped an ITR exhaust manifold?
t..
Old Nov 19, 2002 | 04:38 PM
EVOCELICA's Avatar
New User
no the intake manifold, sorry i should have remembered
Old Nov 20, 2002 | 06:17 AM
EVOCELICA's Avatar
New User
ttt
Old Nov 20, 2002 | 07:11 AM
Desslok's Avatar
If the car is only at 13 volts running, you need to go get your charging system checked out. Pep Boys and Autozone will do this for free.
Old Nov 20, 2002 | 11:44 AM
EVOCELICA's Avatar
New User
it varries from 13 - 15 volts if i remember correctly at least that is what the turbo timer reads
Civic98KH
15
Dec 10, 2012 08:26 PM
turbo gli
Jun 6, 2009 12:29 PM
longhair77
Jun 23, 2006 11:00 AM
samvtecaccordsport
Jul 18, 2004 02:13 PM
VTC_CiViC
Nov 8, 2002 02:55 PM
