Need an answer QUICK.. LOOK!!!!!
My engine wont run it turn over and then will run and then stumble, we pulloed the spark pulgs and number one the little notch was hitting the electrode. It sounds like the engine is knocking. What could the problem be??? We gapped the sparkplug but it still wont run..
H-T Poker champion
Re: Need an answer QUICK.. LOOK!!!!! (McD)
Engine kocking is never good.. did you miss shift or anything recently? Knocking from the engine usually means something in one of the cylinders is wrong.. like a bent rod or something.. which would suck for you!
New User
Re: Need an answer QUICK.. LOOK!!!!! (Hatchy-Ownzjo0)
GAP BRIDGING
Symptoms: Combustion deposits lodge between the electrodes. Heavy deposits accumulate and brige the electrode gap. The plug ceases to fire, resulting in a dead cylinder.
Recommendation: Locatoe the faulty plug and remove the deposits from between the electrodes.
MECHANICAL DAMAGE
Symptoms: May be caused by a foreign object in the combustion chamber or the piston striking an incorrect reach (too long) plug. Causes a dead cylider and could result in piston damage.
Recommendation: Remove the foreign object from the engine and/or install the correct reach plug.
pumpkyn
26
10-01-2006 01:14 PM
trustbuddy
01-15-2006 12:25 PM
trustbuddy
01-14-2006 08:27 PM
