need help knowing how to inspect an engine
Old Mar 15, 2012 | 09:30 PM
beaterman's Avatar
Default need help knowing how to inspect an engine
My question is this, I am going to buy a long block from someone that has the engine out of the car. They say the engine is good but how do you really know with out opening it up? I have helped build one engine but it was the persons original engine so he knew what was in it. How can I check to make sure its not messed up internally, like a broken rod or bearing or something?
Old Mar 16, 2012 | 05:40 AM
fcm's Avatar
fcm
Old Fart
Default Re: need help knowing how to inspect an engine
I would start with a compression test. 94
Old Mar 16, 2012 | 01:17 PM
D.A9 GUY's Avatar
you gotta though the dice.... i mean its really not a look at it affair,you gotta hear it ,and look inside if its f***ed up build it if not still build it...unless it was destroyed.
Old Mar 16, 2012 | 01:35 PM
DirtyDA9's Avatar
Turn the crank by hand with a long wrench like a torque wrench. Take the valve cover off and rotate the engine again. Listen and feel for binding, and spots where it gets hard to turn. With the spark plugs out btw.
Old Mar 16, 2012 | 02:18 PM
beaterman's Avatar
Alright thanks. I figure turning the crank would be a good place to start. Im still debating what I want to do. My car is burning oil pretty bad and I would like to swap the engine out and build my gsr engine while I still drive my car to work.
Old Mar 16, 2012 | 04:00 PM
Turboteg27's Avatar
take the oil pan off and check for metal shavings. pull the valvecover off and give it a look. but really its a crap shoot. u really cant tell without doing a compresion check.
justvisiting
Aug 9, 2009 08:27 PM
cats_on_ice
May 3, 2006 10:30 PM
92HB_HB
Jan 24, 2004 08:50 PM
Sinner
Jun 16, 2003 10:09 PM
