Need advice: swapping del sol seats into my eg hatch.
Old 07-13-2003, 08:34 AM
JJW
JJW's Avatar
Default Need advice: swapping del sol seats into my eg hatch.
I know I've just got to switch the rails between my stock seats and the delsols but is there a guide on how to go about this?
It seems that on one side of the seat, the whole bracket assembly should be swapped but on the side with the reclining mechanism only the very bottom part should come off.
Any help is appreciated!
Jim
Old 07-13-2003, 08:35 AM
Former Moderator
B18C5-EH2's Avatar
Default Re: Need advice: swapping del sol seats into my eg hatch. (JJW)
Why would you swap brackets?
I've got two buddies that swapped Del Sol seats in their hatches and if I'm not mistaken neither of them swapped rails.
They *should* bolt right in.
Test fit them first before you begin to unbolt those rails!
Old 07-13-2003, 08:38 AM
al3e's Avatar
yeaaaah mine. did the same thing. just bolted right up.... i want del sol seats hella nice
Old 07-13-2003, 08:49 AM
allmtr's Avatar
Default Re: Need advice: swapping del sol seats into my eg hatch. (al3e)
HERE U GO! U CAN THANK ME LATER!
http://members.tripod.com/gamby123/id33.htm
Old 07-13-2003, 11:07 AM
rodrez.'s Avatar
Default Re: Need advice: swapping del sol seats into my eg hatch. (B18C5-EH2)
When I put mine in, all the holes didn't line up correctly, so I swapped the rails. It's very easy, took about 20minutes to do both seats.
Old 07-13-2003, 12:19 PM
SloCivicHMM's Avatar
I had to swap rails in mine too...I was confused....I thought they bolted in too......damn....anyone know why some do and some don't??
Old 07-14-2003, 11:10 AM
JJW
JJW's Avatar
Default Re: Need advice: swapping del sol seats into my eg hatch. (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">When I put mine in, all the holes didn't line up correctly, so I swapped the rails. It's very easy, took about 20minutes to do both seats. </TD></TR></TABLE>
Yea, it seems like it would be easy. Did you understand what I meant in the original post about each side of the rail being different? Does just that bottom piece gets swapped? Or do I disconnect each bracket from the seat back and bottom?
Is it possible to disconnect the hinge bolt and effect the swap in that way?
Jim
Old 07-14-2003, 11:12 AM
743's Avatar
you need to take off the whole thing, not just the slider.
Old 07-14-2003, 11:17 AM
JJW
JJW's Avatar
Default Re: Need advice: swapping del sol seats into my eg hatch. (-743-)
Nuts. Are you sure? This means partially removing the upholstery on my stock seats. I hate hog rings.
Jim
Old 07-14-2003, 02:07 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Why would you swap brackets?
Test fit them first before you begin to unbolt those rails!</TD></TR></TABLE>
I have del sol seats in my EH. There is no way you are getting them in you car with the del sol rails/sliders unless you only use 2 holes, or you drill into the car. As for undoing uspholstery, like the other guy said, definitely not needed to do. There is 2 bolts on one side, 3 on the other.
jdmhatch1
05-24-2008 09:59 PM
VTECdohcter
08-28-2007 01:36 AM
x_tc-Dae
15
12-30-2004 07:08 PM
BlackNoise
03-20-2003 09:23 PM
LSVtecEK1
01-23-2003 09:34 PM
Quick Reply: Need advice: swapping del sol seats into my eg hatch.
