mount question
mount question
Sorry if this has been covered but I have 95 ej and Im swapping in a b18b1. I know which teg mounts are needed. But for the rear "L" bracket can I use one from the 99 civic si or does it have to be teg. Also the lower torque mount brackets ;same thing?
Re: mount question (mphinesee)
Passenger side mount and rear sub-frame mounts are the same. You need to use the rear transmission "L" bracket from a 94+ Integra or 92-95 JDM B16, and NOT the one from the 99 Si as it won't fit in the EG/EJ chassis. The driverside, either stick with the Integra bracket (on the block) and mount, or use the Civic bracket and mount, but you can't mix & match as you'll see the studs don't line up the same for both driver side mounts.
Re: mount question (Newman)
okay thanks that helps alot...do u know about the lower torque mount bracket...the part that is attached to the front/bottom of the transmission....u think i could use a civic si or just stick with the integra one
blueintegra90
06-11-2004 04:03 PM
theturbocivic
11-22-2002 05:26 PM
PhoBichNga
07-21-2002 11:21 AM
