Motor tranny and disc brake swap
I have a 98 non vtec, automatoc with drums that I'm looking to do a swap on. Does anyone know what all of have to grab todo all that? Mainly just the tranny and the disc brakes
I'm not Rick!
Re: Motor tranny and disc brake swap
first the swap.
you need tranny. linkage. manual trans mount
clutch/flywheel(longer flywheel bolts) flex plate bolts r short.
clutch master cylnder
clutch slave cylinder
clutch pedal assembly from manual ek(96-00)
find the wire to override park and rig it to allow car to start. (search)
brakes.
rear trailing arms from si or dc or eg eg with disc. (rotor, caliper)
brake cabes.
and you should be searching...this stuff is out there. good luck getting your rear trailing arm bolts out,.............................................. ...........................
brakes.
brake cabes.
