motor swap - 94cpe DX auto --> 94 hatch manual (dx?si?vx? not sure)
Old 03-16-2007, 03:34 PM
( o )( o )'s Avatar
Default motor swap - 94cpe DX auto --> 94 CX hatch manual
I'm helping my friend with a motor swap this weekend.
His 94 Civic Dx coupe (automatic) was hit in the rear by an El Camino.
He just picked up a 94 hatch (trim level unknown) that had a GSR(manual) swap, but has no motor right now.
First things first - yank the D motor/tranny from the coupe. I should be ok there.
I'm not yet sure if the hatch has a cable or hydro clutch - So should I also pull the master cylinder (not sure if it is different)?
I'm also told the hatch was rigged for VTEC in the wiring harness...would that simply be an additional wire in the harness, or will I have to rearrange any pins?
Any other pre-planning tips for this swap tomorrow?
Everything should just bolt right up, right? (lol by saying that, it's almost an automatic jinx)
thanks guys
Modified by ( o )( o ) at 11:00 PM 3/16/2007
Old 03-16-2007, 04:04 PM
Luserkid's Avatar
Default Re: motor swap - 94cpe DX auto --> 94 hatch manual (( o )( o ))
Its a little more difficult then you think. The problem with the 92-95's on auto to manual is the mounting point thats on the frame of the car, not the mount bracket like on 96-00. Im not really sure what you could do about that mount to put an auto in a manual car. Might want to call hasport and see if they have any mounts for that.
What youll want to do to make it 10000 times easier is gut the dash's and swap harnesses thatll fix your wiring problem. Other then those 2 things it plug and play.
Old 03-16-2007, 04:13 PM
( o )( o )'s Avatar
Default Re: motor swap - 94cpe DX auto --> 94 hatch manual (Luserkid)
I was already considering the harness swap.
I was completely unaware of this auto/manual tranny mount issue.
(I'll probably just have him jump on craigslist and find a manual d-tranny locally)
Thanks!
any more issues/tips guys?
Old 03-16-2007, 04:35 PM
shrums-EG6's Avatar
just get a 5 speed tranny,. it will be a lot easier
Old 03-16-2007, 09:53 PM
( o )( o )'s Avatar
Default Re: (shrums)
Yeah hopefully he finds one...his cheap $300 shell project just started the nickel and dime process (tranny clutch flywheel, etc)
Old 03-16-2007, 09:57 PM
( o )( o )'s Avatar
Default Re: (( o )( o ))
by the way it turns out the hatch is a CX.
Old 03-20-2007, 06:22 PM
( o )( o )'s Avatar
i just found a cheap 97 d-series manual tranny - will it bolt up to this 94 CX hatch with a 94 DX motor? any mount or electronic issues, or will it bolt right up?
thanks!
Old 03-20-2007, 06:24 PM
Nongan's Avatar
it will bolt right up. all d-series trannies are interchangeable.
Old 03-23-2007, 05:49 PM
( o )( o )'s Avatar
One more question. What is the difference between the 94 CX motor and the 94 DX motor? WIll the CX ecu work on the DX motor?
thebagclip
09-29-2008 11:01 PM
excivicboy96
12-04-2006 11:00 AM
Tippyman
01-06-2006 07:38 AM
S2Krypt
06-07-2002 06:21 AM
Quick Reply: motor swap - 94cpe DX auto --> 94 hatch manual (dx?si?vx? not sure)
