Misfire in vtec -- help please
So my car engages vtec at 5100 revs to 9 but once in vtec stutters on it self bad cleans out some but not all the way its a b16a2 tuned on neptune could it be bad fuel like i said only back fires and misses when locked in vtec.
Re: Miss fire in vtec help please
i could recommend changing the cap and rotor. or clean the cap and rotor and see if it helps at all. scrapping the post off and the edge of the rotor
Missing only in Vtec is not an ignition problem so you should be able to rule out that entire system. The ignition receives more voltage as RPM increases, which is why ignition problems almost always present with at least slight idle problems. Make sure that heat, including both environmental and engine heat, isn't a factor with your problem. Once that's out of the way, you're looking at a timing, fuel or control problem. Control meaning the sensors or ECU programming. Aside from checking the plugs, you may want to borrow a fuel pressure test kit from a parts store and check your fuel pressure with and without the regulator vacuum hose attached to see if you are pushing enough fuel to supply vtec operation.
OP, if you want to come to Federal Way, I have parts to fix it.
Jahtoot84
06-21-2005 06:46 AM
