mini me timing help
Old 11-20-2003, 09:00 PM
Civiclx's Avatar
Default mini me timing help
hey guys, i am doing the mini me in a couple of days, and the thing i am worried about is getting the timing correct, do you have any tips on how to do this? from what i understand timing can be by both the distributor and the cam gear. thanks
btw, the stuff i have is: d16y7 block, y8 head (cam, gear, internals), y7 exhaust mani, y8 intake manifold/tb, p2p ecu (gonna wire up the vtec pressure, vtec solenoid, knock sensor, and convert the iacv to a two wire plug), y8 head gasket, y8 timing belt.
thanks again!
Old 11-21-2003, 06:51 AM
Civiclx's Avatar
Default Re: mini me timing help (Civiclx)
hmmmm...anyone?
Old 11-21-2003, 11:37 AM
Civiclx's Avatar
omg, anyone, absolutely anyone?
Old 11-21-2003, 11:40 AM
2000blackgsr's Avatar
I don't know, but I recommend going through this if you haven't.
Old 11-21-2003, 11:48 AM
Civiclx's Avatar
Default Re: mini me timing help (96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96coupe &raquo;</TD></TR><TR><TD CLASS="quote">I don't know, but I recommend going through this if you haven't.</TD></TR></TABLE>
hmm thanks, i have looked at that ad naseum and i was wondering if anyone has done the y7--&gt;y8 head swap and had difficulties with timing. thanks
Old 11-22-2003, 01:42 PM
Civiclx's Avatar
anyone done this? i know there are a bunch of you mini me'ers out there!
Old 11-22-2003, 08:02 PM
IDriveHonda's Avatar
There is nothing special you have to do about the timing. Before you take it apart make sure you the crank is at top dead center (white line aligned with timing marker) and the cam gear is lined up so that the word "up" is pointing up. Make sure that when you put it back together make sure everything is still alligned. The only reason you would have to change cam timing is if you were using a Z6 cam in a Y8 head to my knowledge. When finished let the car warm up, check the timing and rotate the distributor so that the red line on the crank lines up with the timing pointer. It is kind of a bitch to get the belt back on in the correct position on the cam gear so it could take a few tries to get it perfect. At least for me it is .
Old 11-22-2003, 09:34 PM
Civiclx's Avatar
Default Re: mini me timing help (IDriveHonda)
thanks for the post, thats exactly what i was looking for!
Darrell Woods
11
02-09-2017 08:09 PM
86crxowner
12-02-2014 01:02 PM
EfSedanLove
01-25-2008 02:59 PM
xsenceo89x
12-27-2007 11:45 AM
eg4door
23
06-20-2005 04:10 PM
Quick Reply: mini me timing help
