y8 and z6 timing
Re: y8 and z6 timing (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Z6 = 16*
Y8 = 12*
Buy a Helms.</TD></TR></TABLE>
^^^^^ dizzy timing. the stock cam timing should be 0 deg.
Y8 = 12*
Re: y8 and z6 timing (Hurricane)
I don't think there the same. Ok I got a y8 cam with the z6 pulley in a z6 head so I think there is a timing difference between the two. I want to know if someone knows what my timing sould be at for example 5deg adv on the pulley to make the cam really at 0. I thought the y8 and the z6 have different TDC.
Its about 3-4 deg* I know from installing severall timing gears on z6 and y8 motors.
If you install a cam gear on a y8 and have it set on 0 it will lag and feel slow as ****! YOu have to advance the cam gear 3-4 degress to get it to run like stock.
I learned my lesson from calling skunk when I was installing my first cam gear on a Y8 motor and couldnt get it to run right without advancing it 3 or so degs.
Hope this helps.
Hope this helps.
Where did you get your info from Jlacoy82? Cause if its reliable Im going to remeber your exact deg* for the nextime I Install A timing Gear on y8
Thanks.
Thanks.
Re: (eg4door)
ok so I put my timing to 4.5 adv. and now I can't get my engin to stop pinging. It seems to only stop pinging if I put the cam gear back to 0-2 deg avd? and yes I did my timing. What should I do?
Re: y8 and z6 timing (eK9aT10pSi)
doood didnt anyone read his post before replying. putting a y8 cam in a z6 with a z6 gear. y8 and z6 cams are the same so there is no differance in cam timming, your timming should be set at zero (straight up) unless you are going to advance or retard to change the power curve
Re: y8 and z6 timing (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub »</TD></TR><TR><TD CLASS="quote">doood didnt anyone read his post before replying. putting a y8 cam in a z6 with a z6 gear. y8 and z6 cams are the same so there is no differance in cam timming, your timming should be set at zero (straight up) unless you are going to advance or retard to change the power curve</TD></TR></TABLE>
But the cam gears are different.........
Scroll halfway down, and read.
http://www.d-series.org/forums...17653
Darrell Woods
11
02-09-2017 08:09 PM
devinp52
10-18-2012 02:59 AM
