Y8 head On a Z6 Block Timing Issue
Cam timing issue. With a y8 head and Can do I use the Y8 cam gear to get proper mechanical
Timing? I got a Crower cam na stage 3 for a D16z6 with the Crower adjustable can gear. If I put the Crower Z6 can in the Y8 head, will it work? If so What timing gear Should I use to run the Crower Z6 cam in said Y8 head on my z6 block?
Thank you for All help in advance
Re: Y8 head On a Z6 Block Timing Issue
I was under the impression the Z6 block and the Y7/Y8 blocks were the same deck height so as to handle the longer rods. In which case the timing shouldn't be off the 1/2 tooth like it is on the shorter D15 block.
PHANTOM MENACE
Correct. In this case there is no need to worry about timing change from the head swap BUT he's using a Z6 specific camshaft. Here he should be using the a 88-95 specific camgear (so as to treat the whole assembly as a Z6) if not already using an adjustable camgear.
Loves Tossing Salad
I remember when I had my adjustable gear for a Y8, it gave two separate settings, one for the Y8 and one for the Z6. I assume that means something is different then, yes?
Math is not my issue. Tech is. Once I get the numbers I Can Figure out the rest..
Never the less. I Thank Everyone for there input.
OBD1 and I think OBD0 is keyed a half a tooth off of OBD2 motors. That's why you can adjust the half a tooth variance from the deck height of some mini me's by swapping the cam gear.
Darrell Woods
02-23-2017 06:46 AM
dustinbs144
07-15-2010 01:56 AM
jvillagran2000
27
12-03-2008 05:06 PM
The Internet Tough Guy
11
05-03-2006 05:23 PM
