milky brown stuff under oil cap,wtf???
Old 05-06-2003, 01:53 PM
stockegsix's Avatar
Default milky brown stuff under oil cap,wtf???
i remove my oil cap and saw this mily brown thing build up.
by the way its in a turbo b16a that not running right now? could it be piston rings or head gasket?
Old 05-06-2003, 01:55 PM
HXMan's Avatar
Default Re: milky brown stuff under oil cap,wtf??? (zzZZzzleeperCX)
Could be oil mixing with coolant...means blown headgasket.
Old 05-06-2003, 02:06 PM
Quik Chris's Avatar
Default Re: milky brown stuff under oil cap,wtf??? (HXMan)
Yeah headgasket for sure. Now look in your radiator or drain it and see if there's oil in there.
Unless you over-filled the oil during the last oil change
Old 05-06-2003, 02:23 PM
stockegsix's Avatar
could "blow by" be causing this too.
which head gasket to use, should i go oem or after market ones. this is a bone stock b16a @7 psi of boost
Old 05-06-2003, 03:07 PM
hndarcrb18c1's Avatar
If its turbo more than likley its a cracked sleeve... too much boost on stock block....
Old 05-06-2003, 03:09 PM
moondoggy's Avatar
Default Re: milky brown stuff under oil cap,wtf??? (hndarcrb18c1)
could be water?
Old 05-06-2003, 03:12 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndarcrb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">If its turbo more than likley its a cracked sleeve... too much boost on stock block....</TD></TR></TABLE>
riiiight because its turbo, the first thing to break are the sleeves.
pull the oilpan
drain the coolant
look for anaomilies. if the HG is gone you will find "peanut butter" substance of oil mixing with coolant.
Old 05-06-2003, 03:15 PM
GOLDBERG's Avatar
what the HELL are you talking about???????????????????????
Old 05-06-2003, 03:45 PM
Turbo Powa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Could be oil mixing with coolant...means blown headgasket.</TD></TR></TABLE>
Old 05-06-2003, 03:54 PM
decypha's Avatar
blown head gasket....good time to upgrade..
you can use a stock one but if you are interested..i happened to have one for sale made by inline pro..
let me know.
Old 05-06-2003, 04:24 PM
stockegsix's Avatar
Default Re: milky brown stuff under oil cap,wtf??? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
pull the oilpan
drain the coolant
look for anaomilies. if the HG is gone you will find "peanut butter" substance of oil mixing with coolant.</TD></TR></TABLE>
yeah its kinda like a "peanut butter" substance, so its the headgasket. now how hard is it to change one.
Old 05-06-2003, 04:26 PM
Kamin's Avatar
it can be done in a few hours if you know how to do it, if you dont, give yourself a weekend and make SURE to use a helms, step by step.
a shop will charge 400-600+ for a HG replacment.
Old 05-06-2003, 05:32 PM
Default Re: milky brown stuff under oil cap,wtf??? (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">
what the HELL are you talking about???????????????????????</TD></TR></TABLE> Oh im sorry I forgot Most of the wanna be turbo goons dont run COPPER headgaskets or HEADSTUDS wich would eleivate the blown headgasket problem!!!!! DUH If youre gonna spend 2,000 or more on a turbo why not do those simple things first???
Old 05-06-2003, 05:34 PM
pull the oilpan
drain the coolant
look for anaomilies. if the HG is gone you will find "peanut butter" substance of oil mixing with coolant.</TD></TR></TABLE> ALso the same symptoms as a cracked sleeve
Old 05-07-2003, 01:20 PM
HXMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndarcrb18c1 &raquo;</TD></TR><TR><TD CLASS="quote"> Oh im sorry I forgot Most of the wanna be turbo goons dont run COPPER headgaskets or HEADSTUDS wich would eleivate the blown headgasket problem!!!!! DUH If youre gonna spend 2,000 or more on a turbo why not do those simple things first???</TD></TR></TABLE>
True, but most people that are running a stock block would probably rather blow a headgasket then blow a ringland or sleeve.
Old 05-07-2003, 08:39 PM
stockegsix's Avatar
True, but most people that are running a stock block would probably rather blow a headgasket then blow a ringland or sleeve.</TD></TR></TABLE>
i hope its only a head gasket, im gonna try to change it myself. ive only been boosting not even for a week and boosted no more than 15 times, im really upset right now and just wanna get this stupid thing over with, it sucks not having a car
Old 05-07-2003, 10:22 PM
Quik Chris's Avatar
Wanna be turbo goons running a copper headgasket? What?
I can see the sleeve cracking on a B20, but not on any other motor.
Old 05-08-2003, 07:53 AM
Default Re: milky brown stuff under oil cap,wtf??? (Quik Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris &raquo;</TD></TR><TR><TD CLASS="quote">Wanna be turbo goons running a copper headgasket? What?
I can see the sleeve cracking on a B20, but not on any other motor. </TD></TR></TABLE>
&lt;&lt;&lt;&lt; B18c1 stock block + 17 lbs of boost = cracked sleeve
Old 05-08-2003, 07:58 AM
TSPeed Factory
AzntaggeR's Avatar
doode that's not good at all...i think it could be water. maybe a bad gasket.
Old 05-08-2003, 08:33 AM
senior gold member
Ivan's Avatar
yup I agree with everyone else. It sounds like a headgasket.
Old 05-08-2003, 11:02 PM
stockegsix's Avatar
Default Re: milky brown stuff under oil cap,wtf??? (Ivan)
thanks for all the replies. but anyways me and a friend will be installing a newer b16a block in my car.
Old 05-09-2003, 03:12 AM
Mr. Badwrench
boostedcivicsir's Avatar
if it is under the cap it could be simple as just plain old moisture.
Old 05-09-2003, 07:17 AM
Why a newer block???
Hiboost 2.0
08-14-2011 06:34 PM
nihad
10-01-2008 03:22 PM
scartail
04-04-2005 04:05 AM
BooSTED IsLANDER
02-09-2004 01:35 PM
GruvyTune
10-16-2003 09:20 PM
Quick Reply: milky brown stuff under oil cap,wtf???
