oil from a headgasket leak?
Old Oct 16, 2003 | 09:32 AM
GruvyTune's Avatar
New User
Default oil from a headgasket leak?
2001 prelude:
i've been seeing a drop or 2 of oil a day at the bottom of my built block. i think i now have it narrowed down to the rt side back corner of the block at the junction of the head and block. no oil from the new distributor seal or cam seal. seems right there at the headgasket.
I am very dismayed to say the least....
its a GE sleeved block with stock headgasket sprayed with permatex copper in 2 coats and then bolted with ARP's to the recommended 78ft-lb. i torqued them, loosened them just a bit and retorqued. engine only has 500miles on it and hardly seem more than 2-4psi boost so far.
any suggestions? do little leaks like this ever close up with enough heat cycling?
is the permatex copper spray known to allow some oil leaking?
likely it oil seeping from an oil return galley since its not spurting out at all so i imagine its not worth pulling the head to replace it for such a small leak?
thanks
Old Oct 16, 2003 | 06:28 PM
GruvyTune's Avatar
New User
Default Re: oil from a headgasket leak? (GruvyTune)
anyone have this happen?
Old Oct 16, 2003 | 09:20 PM
eg_type_r93's Avatar
have the shop that built the motor take a look at it
this sucks man sorry to hear
ValleySyder
Aug 24, 2009 06:44 PM
all-mtr-teg
Sep 11, 2007 05:17 AM
bigbadboy
Mar 6, 2007 09:21 AM
GruvyTune
Oct 24, 2003 04:05 PM
four27
Jan 17, 2002 12:10 PM
