Map sensor problems...
Old Nov 26, 2007 | 06:19 AM
b16jaf's Avatar
Default Map sensor problems...
Hi guys, i've got a limping '94 Sir2 just had honda tell me i need a new map sensor (and quote me silly money), so off i went to the scrappy to try find one. the original item is a denso but the one i got now isnt. anyways its still in limp mode. any ideas? should it be an exact copy? does the ECU need resetting before limp mode is disabled?
cheers.
Old Nov 26, 2007 | 06:48 AM
Probot's Avatar
Default Re: Map sensor problems... (b16jaf)
if there is a CEL (check engine light) on then yes, unplug the battery for a couple minutes, re-connect the battery and then drive around for awhile...if you drive for more than an hour and no CEL comes on then you should be ok. however, if a CEL still comes on then you probably need another new sensor, in any case..if a CEL pops on again, see if its the same code and go from there.
Old Nov 26, 2007 | 06:50 AM
rleonekc's Avatar
Default Re: Map sensor problems... (Probot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">if there is a CEL (check engine light) on then yes, unplug the battery for a couple minutes, re-connect the battery and then drive around for awhile...if you drive for more than an hour and no CEL comes on then you should be ok. however, if a CEL still comes on then you probably need another new sensor, in any case..if a CEL pops on again, see if its the same code and go from there.</TD></TR></TABLE>
Agreed.
Dealerships charge WAY to much, the thing is, some people are stupid enough to pay their high prices.
Old Nov 26, 2007 | 07:15 AM
b16jaf's Avatar
cheers for the advice
also... just incase the sensor isnt the correct one does any1 know the resistance it should read between the pins?
... and shouldnt there be a voltage reading going to the sensor when the engine is running?? (because there isn't) :S
mortificationrock
Aug 18, 2010 08:22 PM
b16jaf
Nov 30, 2007 03:17 PM
EJ1 Type Slow
Jul 28, 2007 12:24 PM
biev
Jul 4, 2007 09:07 AM
kaoss_11
Sep 10, 2006 12:03 AM
