map sensor
map sensor
i got the cel codes 3 and 7..... 3 being map sensor and 7 being TPS. Ive replased both and reset the ecu and im still getting the same codes and everything. Plus the throttle position sensor isnt set it wiggles do i have to have it in a certain position for it to work right ?? Please help. Thanks HT
Re: map sensor (EJ1 Type Slow)
7 views and no suggestions??? please this is making my car runn really wierd and suometimes turn on and then right back off as soon as the check engine light turns on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 Type Slow »</TD></TR><TR><TD CLASS="quote">7 views and no suggestions??? please this is making my car runn really wierd and suometimes turn on and then right back off as soon as the check engine light turns on</TD></TR></TABLE>
you have to calibrate the tps sensor, this is why you continue to have the codes.
here read through this link it should help you.
https://honda-tech.com/zerothread?id=457727
del sol1658
13
09-20-2006 03:15 PM
